Explorer
Feb 26, 2024 1:03 PM UTC
K factor in VND7004AY High Side Driver with Iout = 1A
Hi everybody,
In VND7004AY datasheet in table 8, there are NOT measures of K typical and its drift with Iout = 1 A
Is there any available data ?
The spread between typical minimum and max values is normally related to spread of components tolerance, temperature or ..... ?
We already observed the next post
https://community.st.com/t5/power-management/how-to-calculate-k-factor-in-vnd7050aj-high-side-driver/m-p/580071
Is there any similar data for our part number ?
There's a minimum Iout value, where over this value all measures are reliables.
