Nov 30, 2024 4:55 AM UTC
IPS4260L open load pull-up current tolerance
Is there any tolerance spec available for I_PU (the 20uA pull-up current on the outputs) of the IPS4260L?
Peter BENSCH
Peter BENSCHBest answer
Nov 30, 2024 7:13 PM UTC
Ipu is a simple internal constant current source for which the usual semiconductor tolerances can be assumed, i.e. in the region of approx. 40%. However, there is no publicly documented and therefore guaranteed specification for this.
Does that help you?
/Peter
Peter BENSCH
Does that help you?
/Peter
liampwllAuthor
Dec 1, 2024 1:25 AM UTC
That helps. I assume it's not possible to disable this feature?
Peter BENSCH
Dec 1, 2024 9:25 AM UTC
Correct, the feature Ipu cannot be disabled.
