Feb 26, 2024 1:03 PM UTC
IPS1025H/IPS2050h datasheet update.
i'm using some ips2050h-32 and ips1025h-32 from last year. Checking the datasheets, on the revision history they result been modified on july 2023, on table1, FLTx pins. Compared to the old version, seems that now it's been added the disclaimer of not leave these pins floating, but eventually ground them with a resistor. On our project this it's not been done, so they are floating, because it's based on the old version, how this could affect the proper working of the parts?
Thank you and BR
Apr 30, 2024 3:06 PM UTC
I'm having the exact same situation in a design using the IPS2050HQ with floating FLTx pins. Any update on the reason for the datasheet change?
Thank you!
