othmen.DL.5630172311666206E12
Jul 26, 2019 9:33 AM UTC
Input voltage to STPM34
I want to use the STPM34 board for the metrology of a voltage line with a fairly large voltage value (in the order of kV) since it is commanded to use this module for the metrology of all voltage domains .
The problem that the nominal voltage of STPM34 is only 230V.
Is there a way to solve this problem?
Is there anyone who has used STPM34 can help me?
Thank you.
Nov 17, 2023 8:30 AM UTC
For measuring voltage, you can use a voltage divider to scale the range of measurement. However, measuring current with a shunt is more complex. Be careful when choosing resistors to ensure compliance with the standard.
