Jul 5, 2024 5:15 AM UTC
i2c address of Steval-ISB014V2
I am using StevalISB014V2 for battery monitoring but in data sheet there is no i2c address , i need slave address, read and write address of this module.
AScha.3
Jul 5, 2024 5:49 AM UTC
Seems there is  STC3115 controller , so from its ds:
see:
https://www.st.com/resource/en/datasheet/stc3115.pdf
FaizanAuthor
Jul 5, 2024 8:06 AM UTC
But what exactly is the read address of the STC 3115, i didnt get it, if you know kindly tell me..
AScha.3
Jul 5, 2024 8:16 AM UTC
Read the basics about I2C .
R/W is just the LSB of the address , so 0xE1 = read , 0xE0 = write to =0xExx device.
If using HAL, its doing this for you , if on transaction a read or write is needed.
