Pvalv.1
Aug 31, 2020 11:23 AM UTC
I want to design circuit for mobile charger with universal input voltage range,5V,2A output.Which IC will be suitable for this application? VIPer22ADIP-E
Can i use VIPer22ADIP-E?
Peter BENSCH
Sep 1, 2020 5:42 AM UTC
VIPer22ADIP-E can be used for 10W and wide range (85...265Vac) as you can see from its datasheet, pg 1.
For greater reliability, it may be worth considering the VIPerPlus family for their extended input voltage range, etc.
Have ever tried to design and simulate a power supply circuit using eDesignSuite?
Good luck!
/Peter
