Nov 13, 2024 11:29 AM UTC
I need the name of this sop8 IC
millenium mps 1000 drum module
I need the name of the sop8 integrated circuit. The ST logo on it says ua gb145. The 8th leg is +12 volt input. The 7th leg is gnd. The 3rd leg is 2t1 smd push button. The 1st leg is out +12. Can you tell me what this integrated circuit is?
Peter BENSCH
Nov 13, 2024 11:46 AM UTC
Welcome @Volkann, to the community!
The 2nd line here contains the date code, the marking is at the 1st line, here ending with UA.
Please try to recognize the letters/numbers at the beginning of the first line.
/Peter
VolkannAuthor
Nov 13, 2024 12:10 PM UTC
Thanks for the answer but the numbers and letters before ua have been deleted. I searched a lot but couldn't find anything. If you know this integrated circuit, please help.
Nov 13, 2024 1:00 PM UTC
You'd need an example that was legible. If this one has exploded or vented magic smoke it's going to be near impossible without a schematic or portion of one.
Could try acetone or other methods to inspect or light the part to see or raise the marks.
Might be easier to find someone with a working unit.
