Sep 13, 2024 5:55 AM UTC
How to set the STWLC38 to 15W(EPP)
I use the STWLC38 for wireless charging.
Just set the BPP VOUT to 9V, and other REG is in default value.
In test , the output current around 0.6A . (The chip emits a squealing sound)
If I want to set the Rx to 15W, which REG I need to set.
And I have a question about the RX LDO configuration in datasheet。 There is no detailed explanation regarding the threshold. How should these registers be configured?
Thank you!
willzhouBest answer
Nov 17, 2024 3:34 AM UTC
Hi
please enable RX NEG for EPP mode use GUI, or you can use this link epp file.
https://github.com/STwirelesscharger/STSW-WPSTUDIO/blob/main/a12_wlc38_downfw_epp.bat
willzhouBest answer
Hi
