Central SUPPORT
Senior
Jul 23, 2019 2:18 PM UTC
How to program OTP registers of L9916
We are to evaluating the L9916 (Multifunction alternator voltage regulator...). From the datasheet I learned that there are OTP registers which are programmed by I2C – as described in section “OTP Programming�? on page 30. Okay, but in addition we need a list of the registers and possible values, information which is not included in the datasheet. Please help.
NOTE: This question and answer originated from a customer support case which was handled by us. We regularly review support cases and add any helpful ones here for all to benefit from.
Central SUPPORT
Central SUPPORTBest answer
Senior
Jul 23, 2019 2:21 PM UTC
For programming the OTP registers please refer to attached application note.
Central SUPPORT
Central SUPPORTAuthorBest answer
Senior
