Aqsa
Apr 14, 2023 1:18 PM UTC
How to measure power consumption using STM32F767zi
Hello, I'm working on an STM32F767zi board and want to monitor the power consumption of the MCU using the X-NUCLEOLPM01A. I follow the instructions in the board's documentation to turn off the SB112, which is turned on by default. Can somebody tell me how to go about doing this?
    Bubbles
    Apr 14, 2023 2:54 PM UTC
    Hi @Aqsa​,
    SB means solder bridge. You need to remove the 0R resistor from the SB112 position.
    It's best done using a soldering iron.
    BR,
    J
    Aqsa
    AqsaAuthor
    Apr 14, 2023 3:38 PM UTC
    Is there an alternative to soldering, such as utilising wires to ground?
    Bubbles
    Apr 24, 2023 8:04 AM UTC
    There are alternative solutions like electrically conductive stickers or glues, but I would not recommend those. A bit of soldering is easy enough for anybody.
    BR,
    J
