PGund.1
Dec 18, 2020 8:47 PM UTC
How to I determine the correct Resistor value for setting the current limit on the ST1PS02BQTR Buck Converter?
From looking at the datasheet for ST1PS02BQTR, I was able to determine what the default current limit, and that I just need to place a resistor there to set the current limit, but I didn't see any other documentation about what the relationship between the resistor value and the current limit.
Peter BENSCH
Dec 21, 2020 1:56 PM UTC
Please do not get confused by the words "current limit". Here it means the current limit of the high-side MOSFET switch. Its corresponding values are given in table 6, block Power switch for a resistor of:
  • 0 Ohms: 750...1000mA
  • 1 MOhms: 500...800mA
  • 2.2 MOhms: 250mA
Please remember the function of a synchronous buck converter: it is the peak inductor current, not the DC output current.
Good luck!
/Peter
