How to fine tune the BLDC startup period?
- 5 replies
- 1851 views
HI!
I am evaluating a bldc driver setup for a golf caddy with the stspin3201 eval board. The motor has Hall sensor, so I would like to use it, as the main (and preferably) only sensor. Is it a good idea not to use FOC, only just Hall sensor feedback?
I am having problem with the motor startup period. I use speed control, and the controller have a serious overshoot and a very long setting time. I need the lowest overshoot and the smallest setting time for this application. I have reduced the setting time with increasing Ki constant of the PID controller, but it still overshoots, so I need some advice for the fastest startup with the minimal swing. Can anybody help me? I have attached the datasheet of the motor, and the system parameter headers.
Thank you!#stspin32f0 #bldc #eval #power-stage #rev-up #brushless
