TKlei.5
Nov 5, 2019 7:28 AM UTC
How can I activate the internal clock in STSPIN32F0?
How exactly can I program the internal clock in the STSPIN32F0 chip?
cedric H
Nov 6, 2019 10:46 AM UTC
Hello
This kind of question is almost impossible to answer without additional information.
I would advise you to download the datasheet, and to start a CubeMX project with a F0 MCU matching the one you have inside your STSPIN.
If you want to build a motor control project with ST SDK, the entry point is the ST Motor Control Workbench provided with the release available here :
https://www.st.com/content/st_com/en/products/embedded-software/mcu-mpu-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/x-cube-mcsdk.html
Cedric
TKlei.5
TKlei.5Author
Nov 6, 2019 10:54 AM UTC
Sorry.
At the moment I am testing the Steval-Spin3202 board with the STSPIN3202 chip. My problem is that the board is only working if I connect the USB cable.
Is the Steval-Spin3202 board also working without the USB connection?
