DCyr
Jan 29, 2023 10:57 PM UTC
High-Side Switch VN9004AJTR circuit and program design
High-Side Switch VN9004AJTR is fairly new, so nothing on the web to help with circuit and program design. It has a simple default circuit and MCU programming configuration, but it has some nice features that require more complex programming. Has anyone a schematic and also a C++ sketch to control this device including the fault diagnostics and the current sensing facility?
In the block diagrams, they also reference connections to the IC that don't exist on the physical chip (SEL, SEL0 and SEL1).
https://www.st.com/resource/en/datasheet/vn9004aj.pdf
