SDe w.1
Apr 21, 2020 4:06 PM UTC
Hi, Using the "STEVAL-ISB68WA wireless power receiver evaluation kit" , Nominal chip idle current consumption is 17mA using the default setting programmed into the OTP memory at power-up. Is it possible to reduce this current using the STSW-ISB68GUI
