NHend.7
Sep 10, 2018 2:30 PM UTC
Hi I would like to ask a question regarding the L6924U IC. The SD Pin can I leave that pin Fixed to ground as this will only truly run when power is applied on the Vin.
I have a Li Battery that has a NTC that is rated at 10kohm +/-5% that stops the battery from completely discharging.
