MNEDE.1
Nov 25, 2022 9:33 AM UTC
Hi, I am currently using a STP16CPC26, and due to supply shortage,we would like to replace it. the STP16CPC05 seems a good fit, but I can't really find the differences with the PC26, except for current output (90mA vs 100mA), could you help me ? Than
    Peter BENSCH
    Peter BENSCHBest answer
    Nov 25, 2022 10:33 AM UTC
    Welcome, @MNEDE.1​, to the community!
    Yes, the newer STP16CPC05 can replace the older STP16CPC26 and contains some improvements that make component selection easier (smaller bypass capacitor possible) or the slightly higher maximum driver current.
    Does it answer your question?
    /Peter
    Peter BENSCH
    /Peter
    MNEDE.1
    MNEDE.1Author
    Nov 25, 2022 10:36 AM UTC
    Hi Peter,
    Yes thank you very much for the quick answer.
    Have a nice day,
    M.NEDELEC
    Peter BENSCH
    Nov 25, 2022 11:12 AM UTC
    You're welcome!
    If the problem is solved, please mark this thread as answered by selecting Select as best, as also explained here. This will help other users find that answer faster.
    Good luck and regards
    /Peter
