TSmit
Jul 25, 2018 11:18 AM UTC
Hi all, We are new here. We are thinking of using ST L6203 motor drivers on our robots and are wondering if it is recommend to control motor speed by PWN on the enable pin or is better to PWN either IN1 or IN2 depending on direction.
http://users.ece.utexas.edu/~valvano/Datasheets/L6203.pdf
 We've had quiet a discussion about this and it would be great to know which method is preferred.
Cheers
Terry
    Enrico Poli
    Aug 16, 2018 9:34 AM UTC
    Usually PWM on the IN signals is preferred because two reasons:
    1. Less power dissipation (recirculating on the embedded diodes dissipates a low of energy)
    2. Lower current ripple
