VLAVI.1
Mar 6, 2023 9:33 AM UTC
Hi , about the VN9008AJ, do I have to connect the power tab to the ground?
    Peter BENSCH
    Peter BENSCHBest answer
    Jan 14, 2024 6:07 PM UTC
    The confirmation comes late, but may still be interesting for later readers: yes, the bottom slug is the VCC connection, often connected to VBAT. Unfortunately, this was neglected to be mentioned or labelled in the data sheet, but in the data brief of the comparable EV-VN9007AJ it can be recognised with pin number 0.
    /Peter
    Jan 14, 2024 2:29 AM UTC
    I have been reading all the information and although is not so clear, the power tab is the only option to connect Vcc.
    Peter BENSCH
    /Peter
