Jul 3, 2024 4:28 AM UTC
Handling of unused pins of STWLC38
I'm currently considering using STWLC38.
I have a question about connecting unused pins.
How should unused pins be handled?
(GPIO, SCL, SDA, INTB, VS, etc.)
Regards,
Ryoma
willzhouBest answer
Jul 3, 2024 6:04 AM UTC
Vs pin can be open, you can refer to our small board
Jul 3, 2024 5:44 AM UTC
Hi Ryoma
 for unused pins i suggest floating, SCL/SDA is used for MCU/AP control or external to updated fw. If SCL/SDA is not used, i strongly suggest you set SDA/SCL pin as test point in the pcb for future update fw.
RyomaAuthor
Jul 3, 2024 5:55 AM UTC
Hi willzhou,
Thank you for your prompt response.
I'll set SDA/SCL pin as test point as you suggested.
Let me check again.
May I also OPEN the VS pin?
Currently, only Rx mode will be used.
willzhouBest answer
