JFern.5
Dec 29, 2020 2:25 PM UTC
GPIO vs SPI for LED1642GW
Well, as you can see in the datasheet and the application note for LED1642GW, It doesn't use pure SPI, since it doesn't use CS but it requires the Latch Enable (LE) signal.
I'd actually like to write an application to manage multiple LED drivers but the important point is that I'd like to do it for an embedded system based on iMX6, instead just a microcontroller. This apparently could be an issue because SPI spec has not any signal intended to play the role which LE requires. That's why I've been considering to develop from scratch the protocol using GPIO.
What do you think?
Mazen Aljeddani
Dec 29, 2020 3:52 PM UTC
I don't think that developing the complete SPI protocol using GPIO only for ​one custome signal while the SPI hardware is available.
If I understand your question correctly. ​You
only need a logic not gate to invert the CS signal to be used as Latch Enable, or a a transistor or any logic negation method.
Regards,
Mazen​
JFern.5
JFern.5Author
Dec 29, 2020 5:56 PM UTC
Well, In fact I can invert the CS signal modifying the device tree to make it high-active, however LE requires also to be controlled in a middle of a byte. Am I right?
KnarfB
Dec 29, 2020 5:26 PM UTC
You may look at X-CUBE-LED1642 sample code for the X-NUCLEO-LED16A1 board.
JFern.5
JFern.5Author
Jan 4, 2021 9:23 AM UTC
I don't get the point of using an expansion board like X-NUCLEO-LED16A1 :\
KnarfB
Jan 4, 2021 9:34 AM UTC
You don't have to use the expansion board, but may check the sample code and adapt to your needs.
