Peter BENSCH
Peter BENSCHBest answer
Sep 26, 2025 7:14 AM UTC
I had another thought and am now quite sure that I was mistaken and that it is the LD1086DT33TR, with 1086 on the second marking line and 33 on the third, where only a 3 can still be seen.
Good luck!
/Peter
Sep 22, 2025 9:07 PM UTC
These are easier to find if you post a picture of the marking, or at least the type of component and package.
Sep 23, 2025 7:17 PM UTC
Sep 23, 2025 7:46 PM UTC
So DPAK package, probably a mosfet.
Relevant marking is the 1Qxx line and the next. Maybe 1Q86? 1Q66? Nothing came up.
Perhaps @Peter BENSCH can find it.
Peter BENSCH
Sep 23, 2025 8:11 PM UTC
Ironically, lines 2 and 3 mentioned by @TDK, which contain the relevant marking, are practically illegible. I could also piece together 10P6, which would stand for the STD10P6F6.
Without sufficient cleaning of this area and further, sharper photos, possibly from different angles, it is unfortunately not possible to make a precise statement.
/Peter
Sep 23, 2025 10:42 PM UTC
thanks
Peter BENSCH
Good luck!
/Peter
