May 21, 2025 10:43 AM UTC
EVAL-L9963E-MCU GUI: balancing not working on 4-cell battery
Hi, i made up a set up of 4 cells and I connected them to the connector of eval-l9963e-mcu. I already changed 4 cells, cause it seems like there is a dissipation for the cells. When I active the balance by GUI i don't see that the cells are balancing, oyherwise they seem like are discarge fast.
Can I know if there is someone that have used the GUI and if he as find problems like mine
Thank you so much
Max VIZZINI
May 28, 2025 4:26 PM UTC
Please notice that the tool you are using is out of support.
A getting started User Manual:
https://www.st.com/resource/en/user_manual/um3185-getting-started-with-autodevkit-battery-management-system-bms-evaluation-boards-stmicroelectronics.pdf
Best Regards,
AutoDevKit Team
