jimmjimmshen
Nov 12, 2015 9:50 AM UTC
eval-L6470 firmware
Posted on November 12, 2015 at 10:50
hi, i want to know where can i get the source code for eval-L6470 board default firmware? i got fwpspin_discoveryboard_v205.hex file, it work but shows error light i want to trace the error so i need the source code. i only find firmware with library project but i looks little different with fwspin one
dlindstrom13
Nov 12, 2015 8:18 PM UTC
Posted on November 12, 2015 at 21:18
what error light are you talking about?
jimmjimmshen
Nov 13, 2015 12:40 AM UTC
Posted on November 13, 2015 at 01:40
In the case the ready led and error led switch on and not blinking. i read the user manual it shows:
– either the board ID is not recognized by the FW (bad FW versions used)
– or there is a problem with the SPI (no connection between the MCU and the L6470
via the SPI)
– or there is no 5 V - 45 V DC power supply.
i'm sure the power supply is fine then i replace the L6470 chip problem still there.
Gigi
Jan 7, 2016 5:23 PM UTC
Posted on January 07, 2016 at 18:23
Ciao
For question regarding stepper motor control I suggest to try this forum
https://my.st.com/public/STe2ecommunities/motordriver_ics/Lists/Motor%20Driver%20ICs%20and%20Boards
Ciao
Gigi
