Sep 26, 2025 7:45 PM UTC
ECMF4-20A42N10 vs ECMF04-4HSWM10
Please confirm if ECMF04-4HSWM10 is possible replacement for ECMF4-20A42N10?  ECMF4-20A42N10 is in LTB status and we need replacement part with "recommended for new design" status.
Thanks,
Quynh
Peter BENSCH
Peter BENSCHBest answer
Sep 29, 2025 7:54 AM UTC
Welcome @qnguyen, to the community!
You can consider the ECMF04-4HSWM10 as a possible replacement for the ECMF4-20A42N10, but it is neither a drop-in replacement (shorter package with a pitch of 0.4mm instead of the previous 0.5mm), nor are the technical data (e.g. frequency-dependent attenuation) absolutely identical.
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
qnguyenAuthor
Sep 29, 2025 1:21 PM UTC
Thanks Peter.
Quynh
