Welcome @SERGIO-M, to the community!
You can find all of these CAD libraries on the respective product website in the CAD Resources tab. Then select "Start your design with UltraLibrarian", select the desired model and finally select the Eagle6 Library format under Autodesk:
Hope that helps?
Good luck!
/Peter
