Qmai.1
Nov 17, 2021 9:04 AM UTC
Disable Vbus in both source/sink role during operation
Hi everyone,
I am looking the way to disable charge and enable charge for external device wihin STUSB1602. I guest the register TYPE_C_CTRL 0x11 may help but don't know how to the way to do.
Does someone try that? Please help. Thanks in advance.
NBALL
Nov 17, 2021 10:47 AM UTC
Hello
Sorry but we are not able to understand properly your request.
Could you please explain a bit more what you would like to do ?
Regards,
Qmai.1
Qmai.1Author
Nov 17, 2021 2:30 PM UTC
Thanks for reply. Let's me explain a bit:
I have STUSB1602 connecting to CPU via I2C bus, use to charge external type-C device. My expectation is: I can stop charging if the system has some problem like over temperature, low power, ... And it can start charging again if system is good. I read the device document but didn't see the way to do. Please help.
