MLuca.2
Oct 9, 2022 12:47 AM UTC
Disable L6924D maximum charging time
According to datasheet, L6924D has the possibility to set a maximum charging time, defined according to the capacitor connected in TPRG pin. But what should be done if the maximum charging time limit is undesirable?
Can I short TPRG to GND to achieve an "infinite" capacitance, resulting in an infinite maximum charging time?
MLuca.2
MLuca.2Author
Nov 24, 2022 10:02 PM UTC
Hey guys, someone knows what will happen if I short TPRG to GND? The L6924D will still work properly, without the maximum charging time limit?
May 7, 2024 12:22 PM UTC
Anyone with an answer to this forum question yet?
