joaosilva
Nov 29, 2018 12:41 PM UTC
Converts DC-DC PV in series
Hi, I have questions about how serial DC-DC converters work for photovoltaic systems. For, the current in the output tends to be different due to MPPT, which would be several sources of current in series. I read the manual that explains the SPV1020, but it talks about setting the output voltage, something that is not done in inverters of strings, so how can I turn on the inverter?
