Dec 27, 2024 6:12 AM UTC
Clearance problems in the Gerber Files “en.stdes-2kw5ch48v-gerber”
Hi there,I downloaded the gerber file “STDES-2KW5CH48V GERBER ” and found that there is obvious wrong with copper pouring clearance. For example the clearance between main lines and ground is less than 15 mil.
Peter BENSCH
Jan 30, 2025 12:41 PM UTC
Welcome @JamesWang1, to the community!
Many thanks for your valuable advice!
The copper pour clearance is indeed too small in several places, which is probably due to an early development stage of the layout that was inadvertently uploaded. However, all the tools starting with STDES- are only design studies and therefore not available for purchase.
I will contact the development team and ask for corrections.
Thanks again for your help!
/Peter
