HALNA.2
Aug 3, 2021 8:04 AM UTC
cascade clock feed of multi STPM3X chips?
Hi, I would ask a question about STPM3X, when I use multi chip of STPM3X, I can use One crystal and then cascade clock feed (Figure 27 in datasheet). Does this change the performance and the power consumption for the first master chip and slave chip?
Peter BENSCH
Aug 3, 2021 12:08 PM UTC
No, cascading the clocks does not change either the performance or the power consumption of the connected devices.
/Peter
