Jan 30, 2024 12:57 PM UTC
Cant Identify TVS SMD DIODE "G3 019"
Hi I cant figure out which is the correct Diode. It was mounted in a Charging (12/24V DC input) device for ADALIT Firefighter Light .
Thanks for your Help
Tesla DeLoreanBest answer
Jan 30, 2024 5:23 PM UTC
It's a TWO LETTER MARKING CODE
https://github.com/cturvey/RandomNinjaChef/blob/main/stdiode.txt#L15  SMAJ30A CK
It's not terribly clear in your image, so an educated guess. You might be able to get a clearer image, angle, or another board with the same part. Get better imagery, or attach the original, not screen shot of another image on a phone..
See also "DIODES INC" brand
https://www.littelfuse.com/media?resourcetype=datasheets&itemid=09a6ae9a-73cb-4ac4-acac-e6dab92ab953&filename=littelfuse-tvs-diode-smbj-datasheet
Jan 30, 2024 1:39 PM UTC
CK ?
SMBJ30(C)A
Jan 30, 2024 3:46 PM UTC
what does CK mean?
