Visitor
Oct 7, 2026 1:29 PM UTC
Can the EVALSTPM-3PHISO board support Rogowski coils?
Hi there.
I have been asked to look at your eval board, EVALSTPM-3PHISO. The question is, i want to use Rogowski coils, can this board accept them or do i need another product.
Many thanks
Ian
loveforcircuitsBest answer
Oct 7, 2026 1:42 PM UTC
The EVALSTPM-3PHISO is designed for current transformers. A Rogowski coil cannot normally be connected directly to its current inputs.
Rogowski coils produce an output proportional to di/dt. They therefore require an integrator to convert the signal into a voltage proportional to current.
Visitor
Oct 7, 2026 2:57 PM UTC
Thank you for the reply. It confirms what i was thinking. I will use the reference design and alter it to interpret the di/dt signal.
Many thanks
