JackyCheung
Sep 28, 2014 2:21 PM UTC
Bus Voltage Sensing Formula
Posted on September 28, 2014 at 16:21
Gigi:
         I'm in the Bus Voltage Sensing parameter settings of Workbench when the input voltage is 24V, I am a divider resistor R1 = 51K R2=1K, how to calculate excuse me my Bus voltage sensing network partitioning factor?
 Best Regards
 Jacky
Gigi
Sep 29, 2014 7:20 AM UTC
Posted on September 29, 2014 at 09:20
Ciao Jacky
Usually the Bus Voltage Sensing is done with a simple voltage divider.
Considering the one explained
http://en.wikipedia.org/wiki/Voltage_divider
 you have to compute the Vin/Vout ratio that depends only on the resistors network: Vin is the DC bus voltage and Vout is the input of the ADC of the micro.
In your case, I assume that the R2 is between Vout and ground.
Bus Voltage Sensing = (51K + 1K)/(1K) = 52
This mean that you are scaling 52 times the DC bus voltage -> 0.46V to ADC (exploiting small part of the range. Maybe the petitioning factor can be improved).
Ciao
Gigi
JackyCheung
Sep 29, 2014 4:29 PM UTC
Posted on September 29, 2014 at 18:29
Thank you, the problem is solved.
mikemike9141
Sep 30, 2014 7:54 AM UTC
Posted on September 30, 2014 at 09:54
Hi Gigi,
I would like to comment on a possible improvement on that configuration item. I also stumbled on this for a moment because
- on other locations, the tool asks for a gain (for example, current sensing), which is more straight forward in my opinion.
- for the bus voltage, I can only enter an integer value. In my design, the attenuation factor isn't.
- in the resulting header file, this number is indeed converted into a (floating point) gain.
Frank
