STOMO.11
Aug 22, 2025 4:37 AM UTC
ACST series
I would like to use the ACST series as an AC switch for a 90kHz AC capacitive load. Is this possible?
Peter BENSCH
Peter BENSCHBest answer
Aug 22, 2025 7:49 AM UTC
No, TRIACs are designed for mains frequency and cannot be used at such high frequencies. In addition, you want to switch a capacitive load, which results in large peak currents.
You might be able to solve your problem with fast IGBTs:
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
