galahard
Jul 6, 2005 10:20 AM UTC
AC 2kW Motor Controller
Posted on July 06, 2005 at 12:20
gaetano
May 17, 2011 8:18 AM UTC
Posted on May 17, 2011 at 10:18
the AC chopper solution can work also for 2 KW AC load if all components are properly dimentioned for this power rate. But, at this power rate, usually the regulation can't be done just changing the voltage level, because the slip can reach prohibitive values and power losses can increase too much.
Normally the best way to control 2KW motor is the V/F regulation approach.
Best regards,
Tanio
galahard
galahardAuthor
I'm developeing controller for 2kW AC Motor. I've found solution for simple AC Controler (AN1512 -
http://mcu.st.com/mcdfiles/AN1512.PDF
) but I don't know if it can work with high power motors. Do you know any solutions or tips how to design such a controller. I'll be grateful for any kind of help.
galahard
[ This message was edited by: galahard on 16-06-2005 19:00 ]
