GZhu.1
Jul 30, 2021 2:03 PM UTC
About Part#T2535-600G.
Could you please help check the normal range of resistance vaule between Pin A1 and Pin G ? Will it be higher than 72.5ohm? Or will the resistance vaule become higher due to some manufacturing process?
Peter BENSCH
Peter BENSCHBest answer
Aug 2, 2021 7:23 AM UTC
The component T2535-600G is a TRIAC, i.e. a semiconductor. The result of a resistance measurement therefore depends on the measuring device used (measuring current, etc.) and is therefore not reproducible. So there is no such thing as the "normal resistance value".
/Peter
Peter BENSCH
/Peter
