貴藤井.1
Jun 16, 2020 12:19 AM UTC
About L6562A operation. Is there a possibility that the IC will breakdown if it is operated above the recommended fswmin value of 20 to 50 kHz described in AN2761?
Peter BENSCH
Jun 16, 2020 12:18 PM UTC
No, the frequency range mentioned in AN2761 is just a typical range.
Limiting values of devices can always be found in the datasheet.
Good luck in designing your device!
/Peter
貴藤井.1
Jun 16, 2020 11:40 PM UTC
Dear peter
Thank you for your reply.
I understand what you said.
I'll continue designing circuit Paying attention to the limitting values of data sheet.
Sincerely,
Takahito
