ludovic-micou2
use EEPROM of STM32
Posted on May 18, 2010 at 11:32
use EEPROM of STM32
#eeprom-flash-emulation
chikos332
May 17, 2011
Posted on May 17, 2011 at 13:51
Hi ludovic,
It is normal that the example of STM32F103 doesn't work on STM32F107 board (if you mean the STM3210C-EVAL). The EEPROM is not the same at all.
For the STM32F103 it is a M24C08 while for the STM32F107 it is a M24C64 and they are very different in addressing modes.
To have the latest driver you should download the last version of library V3.3.0
http://www.st.com/stonline/products/support/micro/files/stm32f10x_stdperiph_lib.zip
or find the extracted driver attached.
x893
I implement AppNote from ST - EEPROM emulation for Maple platform with a little changes and you can use it with FWLib with a little changes. See more here
http://akb77.com/g/mcu/maple-eeprom-emulation-library/
hadi
Hi friends
Have you seen any FWLib library for EEPROM emulation ?
There is eeprom.c & eeprom.h but in std_periph_Lib !
