Senior
Oct 18, 2024 5:56 AM UTC
Unable to pair DWM1000
I am trying to use DWM1000 for ranging as well as communication but I am unable to do it . I debugged the code and Know that Initiator is sending data but is not being heard . The Rx buffer in responder is geting updated by random values.
I have attached the code to both here . If anyone could help it will be very helpful.
https://drive.google.com/drive/folders/16WMlzlzvSzrWMwefvTAwKB4aY1TVz7GR?usp=sharing
https://drive.google.com/drive/folders/14RmWrQQ4oUgmkux6U1B235Gc2GPwN-bo?usp=sharing
Andrew Neil
Andrew NeilBest answer
Oct 23, 2024 10:08 AM UTC
@Rituraj wrote:
No dev kit .
Again, I would strongly suggest that you get one - then you have a known-good starting point.
You are also far more likely to get support on that than on some unknown custom setup.
mƎALLEm
Oct 18, 2024 9:07 AM UTC
Hello @Rituraj ,
Better to attach the code with zip/rar instead of Google drive.
Thank you for your understanding.
RiturajAuthor
Senior
Oct 18, 2024 10:33 AM UTC
@mƎALLEm will make that sure next time.
Andrew Neil
Oct 18, 2024 9:15 AM UTC
You mean this: https://www.qorvo.com/products/p/DWM1000 ?
Did you see their Application Note APS022, "Debugging DW1000-Based Products and Systems" ?
Have you contacted Qorvo for support: https://www.qorvo.com/support/technical-support ?
How do you know that?
Is it sending valid data?
RiturajAuthor
Senior
@Andrew Neil I know that it because an array is being sent and it is hardcoded , also every time transmission happend a variable is incremented . So I wrote on that basis.
I tried connecting at QORVO but did not get a response.
Andrew Neil
Oct 18, 2024 10:59 AM UTC
Does that guarantees that any radio transmission actually took place?
RiturajAuthor
Senior
Oct 23, 2024 7:38 AM UTC
I am working with DWM 1000 and STM32f429zit and stm32g491ret  which I have used and worked fine for data transmission I want to use the same  for the ranging purpose . At th initiator tx_count increases continously as indication of data being transmitted on other hand at responder the rx_buffer is already full with garbage and this stops the responder for completeing the further . If anyone has worked with this in partivcular or knows a way to get rid of the issue kindly respond ASAP.
I have attached both codes to this mail.
Andrew Neil
Oct 23, 2024 7:55 AM UTC
@Rituraj wrote:
At th initiator tx_count increases continously as indication of data being transmitted .
Again, that does not confirm that anything is actually been transmitted to the air.
Don't Qorvo provide tools to "sniff" what's actually being transmitted to air?
The best place to find such people would be on the device manufacturer's forum:
https://forum.qorvo.com/c/wireless-connectivity/10
RiturajAuthor
Senior
Oct 23, 2024 8:06 AM UTC
I already tried to get answers on Qorvo forum but I am getting no response at all.
A Sniff code has been provided but its for a BLE sniffer and I will need to start working on nrf sdk to utilize that.
I checked using a dummy antenna and oscilloscope . I know the wave exists and is being transmitted as I checked on DSO but again I need it to be recieved on DWM1000 module
