uart delay using LABVIEW
Good morning,
I need to send data using UART to a board with a specific delay between single elements, which I obtain as I'm using LABVIEW, but on the board said specific delay is not obtained, and worst of all the delay between datas is not constant. I figured there would have been some additional delay, but is there a way to decrease it or at least make it constant? or is it intrinsic to the UART technology?
Thx all
Andrew Neil
Andrew NeilBest answer
Some more detail would help:
How to write your question to maximize your chances to find a solution
What delay, specifically?
How do you implement that delay?
What do you mean by "elements" here?
  • between each byte?
  • between groups of bytes?
  • other?
@Jack_DB wrote:
I'm using LABVIEW,
LabVIEW is an independent 3rd-party product from NI - nothing to do with ST.
You need to go to NI for support with their product:
https://www.ni.com/en/support.html
https://forums.ni.com/
@Jack_DB wrote:
on the board
What board?
No - it must be something in your setup.
As we know nothing about your setup, hard to guess what it might be.
Try simple something like:
HAL_UART_Transmit( ... );
HAL_Delay ( ... );
PS:
How do you measure this?
What delay values do you see?
#LabViewSupport
Andrew Neil
  • other?
@Jack_DB wrote:
I'm using LABVIEW,
@Jack_DB wrote:
on the board
What board?
HAL_Delay ( ... );
PS:
#LabViewSupport
Jack_DBAuthor
turned out to be a labview problem...
thx anyway
