TrueSTUDIO printf output is limited
Hi there,
I've configured my TrueSTUDIO in the following way:
https://www.youtube.com/watch?v=qSzme7qcBb0, to redirect the output of my printf-function to console. It works, but the output is limited, sometimes if I want to output a bigger amount of characters it just cuts off the end. For example: I want to print a 32 Byte array, that works, but a 64 Byte array is cut off.
I work with a stm32f767zi and TrueSTUDIO. Short explanation of my configurations:
- created a new syscalls.c
- overwrite _write method (send_char)
- enable swv in debugger
- set swv slot 0 active in debugger mode
- start trace
- resume
I appreciate your help.
Thank you very much.
Best regards
WorkingStudent
