Jan 8, 2024 1:09 AM UTC
The following error occurred during deployment to hardware board: No STM32 MCU connected.
Embedded Coder Support Package for STMicroelectronics STM32 Processors.
The following error occurred during deployment to your hardware board: No STM32 MCU connected.
I can fine ST LINK DEVICE in Device Manager and connect STM board in STM32CubeProgrammer.
matlab 2022a.
Peter BENSCH
Jan 8, 2024 6:58 AM UTC
Welcome @afate, to the community!
What ST-LINK are you using?
Did you try to upgrade it using CubeProg?
/Peter
afateAuthor
Jan 8, 2024 9:39 AM UTC
I'm using ST-LINK V2.
I upgrade my ST-LINK to newest version,V2J43S7.
I try to change matlab version,but no used.
In CubeProg,I change shared setting to enable,I think it's the question.
Is our CubeProgrammer using CubeProg command?
Peter BENSCH
Jan 8, 2024 12:10 PM UTC
I don't know how you programme or whether your programming solution uses CubeProg. What happens if you programme with CubeProg and perhaps switch off the option Shared as a test?
afateAuthor
Jan 9, 2024 12:55 AM UTC
I'm using Embedded Coder Support Package for STMicroelectronics STM32 Processors in matlab simulink.
In CubeProg,if I switch off Shared option,Serial Number is unknowned,and press connect unused.
There is my programming solution screenshot.
Peter BENSCH
Jan 9, 2024 8:02 AM UTC
Well, I don't know which tool Simulink from Mathworks uses for programming, so I can't comment on that. But let's take another look at ST-LINK: can you please upload a photo of your ST-LINK, front and back?
