STM32WLE5CCU6 – RF Output Impedance at 923 MHz, +22 dBm (UFQFPN48)
Hello ST Community,
I am designing an RF matching network for the STM32WLE5CCU6 (UFQFPN48) at 923 MHz, +22 dBm.
In AN5457, I found PA output impedance data for 915 MHz (+22 dBm, UFQFPN48), but not for 923 MHz.
I would like to ask:
What is the recommended optimal PA load impedance at 923 MHz, +22 dBm for UFQFPN48?
Can I use the 915 MHz impedance values for designing the 923 MHz matching network?
Does ST provide reference matching component values for this configuration?
Thank you for your support!
