STM32U3 Workshop - NFC
Hello STM Community -
This post is in reference to the recent STM32U3 workshop webinar. I worked through the rather involved / complicated setup associated with the NFC example. Once the code was generated, 23 errors were returned during compilation. Not sure whether to chase down the 23 errors or request a "known good" project ZIP. I really just wanted to see the NFC function with the STM32U3 series MCU's. Pls advise.
Thanks much,
Kelly
KDJEM.1
Hello @Kbitsnbyte ;
Could you please share your project?
If you want to generate code from .ioc file using STM32CubeMX toolchain, I recommend you to copy the .ioc file in a new workspace then generate code and open the project using STM32CubeIDE
Thank you.
Kaouthar
Hello Kaouthar - a few updates:
  • I was able to successfully evaluate the X-NUCLEO-NFC10A1 using an STM32L476RG MCU and the sample project contained here: https://www.st.com/en/embedded-software/x-cube-nfc10.html#overview
  • The "broken" project created as part of the 12/10/25 STM32U3 workshop is attached. It was a good "start from scratch" exercise. Any insights as how to repair or rebuild this project would be appreciated. If relevant, I am using STM32CUBE IDE V 2.0.0 - I believe the workshop procedures referenced an earlier version.
Thanks much,
Kelly
