STM32H755 VBAT Supply from 3.6 V Li-SOCl₂ Battery: Is a Series Diode Sufficient?
On the STM32H755IIT6, can a 3.6 V nominal Li-SOCl₂ cell be connected to VBAT through a single low-leakage silicon diode? Is there a guaranteed minimum VBAT input current when VDD is present, or could VBAT rise above its 3.6 V operating maximum because the diode has almost no forward current? Does ST recommend a particular circuit for this application?
