Sep 10, 2025 10:17 AM UTC
STM32F373VCT6 controller damage or 3.3V to GND short
Hi team.
We have been using the STM32F373VCT6 microcontroller across three different projects for the past three years. However, during testing and debugging time we’ve encountered a recurring issue where the controller is getting short between the 3.3V supply and ground suddenly. This problem has occurred multiple times and is affecting our development process. We kindly request your support in identifying the root cause of this problem.
Andrew Neil
Sep 10, 2025 11:07 AM UTC
You're going to need to give a lot more detail for people to be able to help you with that!
Please see: How to write your question to maximize your chances to find a solution
Ozone
Principal
Sep 10, 2025 11:29 AM UTC
And tell us what you had connected to those boards, especially peripherals with supply voltages of 5V and higher, and those related to inductive loads (like motors or voltage converters).
I have STM32 boards that or more than 10 years old, used frequently, and which still work fine.
HanamantAuthor
Sep 10, 2025 1:03 PM UTC
The supply voltage for pheripheral,ADC is 3.3V max
Andrew Neil
Sep 10, 2025 2:21 PM UTC
The STM32 won't be damaged so long as you keep within the specified limits stated in the datasheet.
This includes storage, handling and assembly - as well as operation.
If you're getting multiple failures, then there must be something(s) wrong with your design and/or your storage/handling/assembly procedures which allow the STM32 to experience stresses beyond the stated limits.
We know absolutely nothing at all about your design, or the environment it operates in, or your storage/handling/assembly procedures - so we can only guess at what might be going wrong.
If you want better help, you're going to have to supply more details!
If you can't share details publicly, then raise a private support ticket: https://ols.st.com/s/
HanamantAuthor
Sep 16, 2025 10:23 AM UTC
ST moderator: Threads merged. In next time please don't duplicate threads. Please keep the discussion in one thread for the same question. Thank you for your understanding.
Ozone
Principal
Sep 16, 2025 10:48 AM UTC
I vaguely remember an almost identical thread here a few days ago.
The cause are the electronics you connected to the STM32 board.
I bet this includes motor drivers and/or voltage converters, both containing relatively large coils and operating on voltages above 3.3V.
It does not matter that the direct connections between those boards and the MCU board are 3.3V or below.
