neoirto
STM32F2 linker script to emulate EEPROM
Posted on May 10, 2015 at 17:03
Hi all,
I try to test the ST example of EEPROM emulation (with 3 variables and page2 + Page3 usage). I build it with success with GCC (EMBLOCKS), but it seems I can't assign the good value to isr vector. I tried a lot of solution with custom linker script, but no way : I can't reset the MCU after upload. Any help appreciated please !!
/* Em::Blocks embedded development Support */
/* Copyright (c) 2014, EmBlocks */
/* All rights reserved. */
/* Redistribution and use in source and binary forms, with or without */
/* modification, are permitted provided that the following condition is met: */
/* - Redistributions of source code must retain the above copyright notice, */
/* this list of conditions and the disclaimer below. */
/* EmBlocks's name may not be used to endorse or promote products derived from */
/* this software without specific prior written permission. */
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY EBLOCKS ''AS IS'' AND ANY EXPRESS OR */
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
/* DISCLAIMED. IN NO EVENT SHALL EMBLOCKS BE LIABLE FOR ANY DIRECT, INDIRECT, */
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
* Linker script for running in internal FLASH on the STM32F215RE
OUTPUT_FORMAT(''elf32-littlearm'', ''elf32-littlearm'', ''elf32-littlearm'')
OUTPUT_ARCH(arm)
SEARCH_DIR(.)
ROM (rx) : ORIGIN = 0x08000000, LENGTH = 512K
ROM (rx) : ORIGIN = 0x08010000, LENGTH = 448K
ROM (rx) : ORIGIN = 0x08010000, LENGTH = 512K - 0x10000
ROM (rx) : ORIGIN = 0x08020000, LENGTH = 320K : marche pas
/* Memory Spaces Definitions */
MEMORY
RAM (rwx) : ORIGIN = 0x20000000, LENGTH = 128K
/* Linker script to place sections and symbol values. Should be used together
* with other linker script that defines memory regions FLASH and RAM.
* It references following symbols, which must be defined in code:
* Reset_Handler : Entry of reset handler
* It defines following symbols, which code can use without definition:
* __exidx_start
* __exidx_end
* __etext
* __data_start__
* __preinit_array_start
* __preinit_array_end
* __init_array_start
* __init_array_end
* __fini_array_start
* __fini_array_end
* __data_end__
* __bss_start__
* __bss_end__
* __end__
* end
* __HeapLimit
* __StackLimit
* __StackTop
* __stack
SECTIONS
.text :
KEEP(*(.isr_vector))
*(.text*)
KEEP(*(.init))
KEEP(*(.fini))
/* .ctors */
*crtbegin.o(.ctors)
*crtbegin?.o(.ctors)
*(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors)
*(SORT(.ctors.*))
*(.ctors)
/* .dtors */
*crtbegin.o(.dtors)
*crtbegin?.o(.dtors)
*(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)
*(SORT(.dtors.*))
*(.dtors)
*(.rodata*)
KEEP(*(.eh_frame*))
} > ROM
.ARM.extab :
*(.ARM.extab* .gnu.linkonce.armextab.*)
} > ROM
__exidx_start = .;
.ARM.exidx :
*(.ARM.exidx* .gnu.linkonce.armexidx.*)
} > ROM
__exidx_end = .;
__etext = .;
.data : AT (__etext)
__data_start__ = .;
*(vtable)
*(.data*)
. = ALIGN(4);
/* preinit data */
PROVIDE_HIDDEN (__preinit_array_start = .);
KEEP(*(.preinit_array))
PROVIDE_HIDDEN (__preinit_array_end = .);
. = ALIGN(4);
/* init data */
PROVIDE_HIDDEN (__init_array_start = .);
KEEP(*(SORT(.init_array.*)))
KEEP(*(.init_array))
PROVIDE_HIDDEN (__init_array_end = .);
. = ALIGN(4);
/* finit data */
PROVIDE_HIDDEN (__fini_array_start = .);
KEEP(*(SORT(.fini_array.*)))
KEEP(*(.fini_array))
PROVIDE_HIDDEN (__fini_array_end = .);
. = ALIGN(4);
/* All data end */
__data_end__ = .;
} > RAM
.bss (NOLOAD):
__bss_start__ = .;
*(.bss*)
*(COMMON)
__bss_end__ = .;
} > RAM
.heap (NOLOAD):
__end__ = .;
end = __end__;
*(.heap*)
__HeapLimit = .;
} > RAM
/* .stack_dummy section doesn't contains any symbols. It is only
* used for linker to calculate size of stack sections, and assign
* values to stack symbols later */
.stack_dummy (NOLOAD):
*(.stack)
} > RAM
/* Set stack top to end of RAM, and stack limit move down by
* size of stack_dummy section */
__StackTop = ORIGIN(RAM) + LENGTH(RAM);
__StackLimit = __StackTop - SIZEOF(.stack_dummy);
PROVIDE(__stack = __StackTop);
/* Check if data + heap + stack exceeds RAM limit */
ASSERT(__StackLimit >= __HeapLimit, ''region RAM overflowed with stack'')
Other modifications :
#define VECT_TAB_OFFSET 0x10000
Tx ! #eeprom #stm32f2
May 10, 2015
Posted on May 10, 2015 at 17:43
See problem is the processor wants bootable code pointers at 0x08000000, you can't change this in a software setting.
You either need to park some vectors there, so if you want ONE binary, then you need to split the ROM in two and carve out pages 0x08004000-0x0800FFFF, ensuring the vectors get placed at 0x08000000 Perhaps something like this...
OUTPUT_ARCH(arm)
SEARCH_DIR(.)
MEMORY
BOOT (rx) : ORIGIN = 0x08000000, LENGTH = 16K
* __exidx_start
* __exidx_end
* __etext
* __data_start__
* __init_array_end
* __fini_array_end
* __data_end__
* __bss_start__
* __bss_end__
* __end__
* end
* __HeapLimit
* __StackLimit
* __StackTop
* __stack
SECTIONS
.boot :
startup_stm32f4??.o(.text)
} >BOOT
.text :
*(.text*)
KEEP(*(.init))
KEEP(*(.fini))
/* .ctors */
*crtbegin.o(.ctors)
*(SORT(.ctors.*))
*(.ctors)
/* .dtors */
*crtbegin.o(.dtors)
*(SORT(.dtors.*))
*(.dtors)
*(.rodata*)
KEEP(*(.eh_frame*))
} > ROM
.ARM.extab :
} > ROM
__exidx_start = .;
.ARM.exidx :
} > ROM
__exidx_end = .;
__etext = .;
__data_start__ = .;
*(vtable)
*(.data*)
. = ALIGN(4);
/* preinit data */
. = ALIGN(4);
/* init data */
. = ALIGN(4);
/* finit data */
. = ALIGN(4);
/* All data end */
__data_end__ = .;
} > RAM
.bss (NOLOAD):
__bss_start__ = .;
*(.bss*)
*(COMMON)
__bss_end__ = .;
} > RAM
.heap (NOLOAD):
__end__ = .;
end = __end__;
*(.heap*)
__HeapLimit = .;
} > RAM
*(.stack)
} > RAM
neoirto
neoirtoAuthor
Posted on May 10, 2015 at 20:42
Ok, I understand... Splitting in 2 parts seems to be a good solution.
So I tried your linker script.
But during upload with ST-LINK_CLI.exe, the verbose output of  ST-LINK_CLI is still reporting ''Adress 0x08010000''.
Do you see something else to try please ?
Is there any way to fill this 2 Sectors with 32K dummy bits by software perhaps (not clean but perhaps good solution) ??
Tx Clive !
neoirto
neoirtoAuthor
Posted on May 11, 2015 at 17:17
Ok it is fixed now.
In startup_stm32f2xx.S : you have to rplace
.section .isr_vector
by .section .isr_vector,''a'',%progbits
