gmate1
Mar 24, 2015 16:12 UTC
STM32F04T6: development wit IAR workbench
Posted on March 24, 2015 at 17:12
I've recently started learning application development on ARM platform STM32F04T6 seem to be a perfect fit for my requirement. In past I did some programming under IAR workbench for TI MSP430 using IAR workbench and hence I wanted to use the same IDE for this (STM32F04T6) microcontroller too. IAR does have a support for this. So far so good, and now I want to use already existing libraries and header files for rapid development, But I can't seem to find the proper header file (let's say, I need some &sharpdefines for register addresses to begin with ). After some googling, I found ''
http://www.keil.com/dd/docs/arm/st/stm32f0xx/stm32f0xx.h
'' file, but If you notice, this file includes some other header files which themselves include some other header files and so on. Because of this inter dependency between various header files, I couldn't use it.
Therefore,
1: Where can I find such header files and/or SDK from ST for STM32F04T6 for rapid development ?
2: how should I go about using such header files and/or such SDK with IAR workbench.
Thanks,
Kumar
#iar-workbenc #stm32f042 #solved
Mar 24, 2015 16:23 UTC
Posted on March 24, 2015 at 17:23
http://www.st.com/web/en/catalog/tools/PF260157
gmate1
gmate1Author
Mar 24, 2015 19:17 UTC
Posted on March 24, 2015 at 20:17
Thank you so much. This is exactly what I was looking for :)
