FedeRico1
May 2, 2019 12:13 PM UTC
ST32F767 Attempt to perform an unaligned access.
Hello Community,
I'm working on a Nucleo-F767ZI board and from yesterday I had this error from Atollic True Studi: Attempt to perform an unaligned access (UNALIGNED).
I followed the instruction reported here.
The enable of Memory Protection Unit does not solved the problem.
How can I troubleshoot this problem?
Thanks for the help!
Federico
May 2, 2019 12:28 PM UTC
Look at the code that's actually faulting and see why it is not using an aligned access.
Reevaluating what you're doing might actually improve performance of the algorithm. ​
